Rotor options?
Old Jul 26, 2013 | 06:45 PM
Default Rotor options?
I bought some spectra rotors a while ago under the recommendation that they work with the XG brake upgrade. Mine are way too small (275mm, vs. the 303mm for XGs) but like a fool I didn't to the research and got burnt $150 for these damn things. When I install them the pads tilt a few degrees, causing the caliper pistons to tilt slightly (asinine tolerances in the casting) which breaks the rubber seal and leaks fluid everywhere. However, correct me if I'm wrong here, but would these not work with the GK brakes? 280mm rotor stock, so they shouldn't have much of a problem.
Old Jul 26, 2013 | 06:50 PM
the xg comes in 2 different size rotors mang, it should work just fine if you have the right caliper/brackets, there is a 10.8" setup and a 12" xg setup. make sure you have the right bracket
SOURCE: im the one that created the damn swap in the first place
Old Jul 26, 2013 | 06:58 PM
Well, I have the 12". And I now have 12" rotors on my car because drill press.
edit:
So basically its using the GK brake then?
Old Jul 26, 2013 | 11:18 PM
Spoiler
I don't understand your question though, what do you mean by
Old Jul 27, 2013 | 12:08 PM
The GK Tibs use a 280mm rotor on the stock unit. The Spectras are 275, a 2.5mm difference in radius so the spectra rotors should work with GK caliper. Except in the form of a a question?
Also, icwutudid
Old Jul 28, 2013 | 12:41 AM
Ah righto
I'd say not, if the pads demand a 300+ mm rotor, going between 275 and 280 won't make them fit
Old Jul 28, 2013 | 09:49 AM
SpoolinShark's Avatar
Vehicle: 2010 Hyundai Accent
You ran into the same problem that I did honestly.. From what I know, the calipers from the 02-05 XG 350 are dual caliper and virtually the same but the only thing that is really different is the brackets that come with them. If I'm not mistaken, you need the brackets for the 02-03 years but don't hold me to that. Also, if you bought the rotors for the Kia Spectra 5, you have the right ones and will just need to get the right brackets. I ended up getting my brackets off of RockAuto fyi. I have a post on the forums detailing like the exact same problem. I'll try to find it for you.
Here's the link to my thread.. you aren't the only person to have this problem. Lol
Linky
Old Jul 28, 2013 | 02:08 PM
pas1216's Avatar
Vehicle: 1991 Impulse RS
So he could have saved a bunch of time and headaches had he just used
Old Jul 29, 2013 | 05:02 AM
I read a lot of threads and like SpoolinShark said they list all years of the XG350. But if I had looked at webtech It lists the rotor sizes and while the 2005 XG shares shares a cliper part number, like Faith said earlier the rear bracket is different allotting a logger rotor. It was more misinformation.
Plus I bought these 2 years ago, I've squirreled away a few things for my most recent upgrade because I couldn't afford the down time back then. Turns out they won't take back rotors that are that old.
My solution:
Picked up some 12" rotors for the 2005 XG and drilled in the 4x114.3 pattern. Shouldn't be a big deal for now. After the motor swap I'll probably run some semis, but on stock power and auto there's no need.
Old Aug 1, 2013 | 03:47 PM
cadbury's Avatar
Vehicle: 1998 Tiburon
What kind of costs is it to upgrade to the 12" XG calipers, rotors, and brackets? And what is the size for the rear set up? I'd be interested in doing a complete swap front and back but it its going to cost a grand or more, then I'll stick with my factory sized slotted rotors from ebay
