I Hate My Tps
Old May 1, 2008 | 06:43 PM
I had a week where my car was running crappy. Idle would fluctuate while I was moving slowly. The RPMs would drop randomly.... It was pissing me off
I was troubleshooting just about everything except the TPS because I had replaced it last month with an aftermarket TPS. Today I decided to depress my TPS to perform the DaeSung bad TPS test and my idle surged. I found out that my lower TPS screw was loose.
Old May 1, 2008 | 06:45 PM
dddude55's Avatar
Vehicle: 2011 Kawasaki ZX6R
I don't even have the bottom screw on mine. Broke it off when i did the TB bypass. For the last year it has only had the top screw holding it in.
Old May 1, 2008 | 07:13 PM
how did it come loose with your craftsmanship? well at least you found it! i can't find sheit. i wish you were around here. i'm doing my best.
Old May 1, 2008 | 07:19 PM
The bottom screw is very difficult to reach without removing the valve cover. I didn't remove the valve cover.
Dude, I keep telling you to come here.
Old May 2, 2008 | 03:07 PM
Whiplash's Avatar
Vehicle: SRT4/Neon SOHC
I hate those things too. I just replaced one, then a month later I have to replace the whole engine.
