I Hate My Tps
I had a week where my car was running crappy. Idle would fluctuate while I was moving slowly. The RPMs would drop randomly.... It was pissing me off
I was troubleshooting just about everything except the TPS because I had replaced it last month with an aftermarket TPS. Today I decided to depress my TPS to perform the DaeSung bad TPS test and my idle surged. I found out that my lower TPS screw was loose.
Vehicle: 2011 Kawasaki ZX6R
I don't even have the bottom screw on mine. Broke it off when i did the TB bypass. For the last year it has only had the top screw holding it in.
how did it come loose with your craftsmanship? well at least you found it! i can't find sheit. i wish you were around here. i'm doing my best.
The bottom screw is very difficult to reach without removing the valve cover. I didn't remove the valve cover.
Dude, I keep telling you to come here.
