Fitting of rear discbrakes and calipers
Old May 21, 2001 | 03:26 PM
you do not need ABS to fit the Discs in place of your drums.
You will need rear wheel bearings, a new brake line from the caliper to the metal hose (I'm guessing this is what they cut when they gave them to you), and you need the mounting bracket for the Caliper.
You will also need the parking brake cable ends from a tiburon with rear calipers, the drum emergency brake cable end setup is different.
That's all that I can think of at the moment. I'll dig through the books and see if I can come up with more.
mailto:adyb@socal.rr.comadyb@socal.rr.com Here's my e-mail for the photos.
[ May 22, 2001: Message edited by: Random ]
