Fitting of rear discbrakes and calipers
Guest
Posts: n/a
Random hi again,
Sorry about the delay of the pictures.I wanna ask sth.I bought the rear discbrakes and calipers from a wrecked tibbie.The shop that i bought them unfortunately had cut off the small hydr.piping when dismantling them(from the wrecked tibbie).What do i need to order from hyundai in order to replace the rear drums?Furthermore my tibby has no ABS.Do I need any other mod or i should just fit them?Please answer me asap.I also need your email to send you my pics.The shop that mod my tibby to turbo wont allow me to put the engines pics on the net,so i will send them only to you!Thanx in advance,Turboman
you do not need ABS to fit the Discs in place of your drums.
You will need rear wheel bearings, a new brake line from the caliper to the metal hose (I'm guessing this is what they cut when they gave them to you), and you need the mounting bracket for the Caliper.
You will also need the parking brake cable ends from a tiburon with rear calipers, the drum emergency brake cable end setup is different.
That's all that I can think of at the moment. I'll dig through the books and see if I can come up with more.
mailto:adyb@socal.rr.comadyb@socal.rr.com Here's my e-mail for the photos.
[ May 22, 2001: Message edited by: Random ]
