Need Some Opinions For Racing Wheels.
Old Apr 26, 2005 | 11:43 PM
OdessitPashka's Avatar
I plan on getting 14" steel wheels from tibby and putting 225/45 drag radials on them.
How much does each wheel weigh?
Anyone willing to sell me theirs for cheap?
thanks
OP
Old Apr 28, 2005 | 05:41 PM
IJSTBRNDU's Avatar
even thought you are going down to a 14" rim steel wheels weight a lot!..you could go with stock tibby rims (they weight less than 14" steel wheels)...also, lightweight rims in a 14" diameter do not cost as much as you'd think..just search a lil youll find a good deal..besides steel wheels bend real easy.
Old Apr 28, 2005 | 06:17 PM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
Get some of those drag rims that are like cast aluminum or whatever, they're cheap and lightweight. I don't even think they comlarger than 15". Try Jegs or some sort of Drag Race King.
Old Apr 28, 2005 | 08:59 PM
well.. I know the new accents come stock with our bolt pattern.. do they have an aluminum rim in a 14 inch size?
Old Apr 28, 2005 | 09:08 PM
CyberShark's Avatar
A stock 14" Tib wheel is a narrow 5.5 inches wide. A stock 15" wheel is a little wider at 6.0 inches, I don't know if that will effect your decision OP.
Yes, the Accent GT does come with 14" wheels Mad.
Old Apr 28, 2005 | 09:53 PM
Mad_john's Avatar
volk TE37. strong,light sweet.
Old Apr 28, 2005 | 10:00 PM
QUOTE (IJSTBRNDU @ Apr 28 2005, 06:41 PM)
How much can they weigh? More than 15lbs? Which stock tibby wheels are you talking about? 15s alloys are 18-19lbs each!!
I actually looked all over ebay, but couldn't find them with 4X4.5! Every wheel has 5 bolt pattern on ebay!
Thanks for recommending Jegs, I found our lug pattern, but wheels are pretty pricey, $135-140 each.
any chance you know how much they weigh?
You think I won't be able to put 225s on 5.5" width?
Where can I get them man?
Old Apr 29, 2005 | 10:26 AM
CyberShark's Avatar
OP, I think 225 may be a bit too wide for a 5.5" wheel. I think the tires that are supposed to go with it are 185, big difference from 225. I've never tried or heard of anyone trying to fit 225's on a 5.5 wide tire so I'm not too sure on this.
As far as Volk TE37's, they are very expensive and will set you back over a grand to get a set brand new. Good luck with your decision.
Old Apr 29, 2005 | 10:32 AM
225 is about 8" wide, I think you are right that 5.5" wheel will be a little too small.
Old Apr 29, 2005 | 12:13 PM
javageek's Avatar
Would you want all four steel 14" rims? I have a complete set.
