Went to the track again :)
Old Aug 2, 2004 | 11:18 PM
OdessitPashka's Avatar
Default Re: Audio question..............
well, as you can see the results.... 4-2-1 is good at mid range and 4-1 will give most of the power at the high rpms, which would be good at the track
Old Aug 3, 2004 | 07:24 AM
CyberShark's Avatar
Default Re: Exhaust
You guys make valid points...decisions, decisions....Oh yea, Odessit, did you have to use a vertical or horizontal cat with that header?
Old Aug 3, 2004 | 10:57 AM
Default Re: Exhaust
huh? What cat? I only had one left, the stock one....
Old Aug 3, 2004 | 12:07 PM
TibRacer01's Avatar
Default Re: A few new engine shots after paint
When you install a header, you remove the first cat that sits vertically. The only remaining cat would be the second one.
Old Aug 3, 2004 | 12:34 PM
CyberShark's Avatar
Odessit, you were able to reuse your stock cat..lucky you. On the 4-2-1 I had to buy a horizontal cat. Tibracer, I only have one cat, my car didn't come with duel cats like some other models.
Old Aug 3, 2004 | 12:48 PM
TibRacer01's Avatar
Default Vinyl Dye
Oh, your question makes more sense now. Sorry, I was just assuming.
Old Aug 3, 2004 | 01:09 PM
CyberShark's Avatar
Default Re: S-AFC Mounting
No problemo Tibracer
Old Aug 3, 2004 | 01:31 PM
Glock33's Avatar
Default Re: Led Bulb Replacement...
cars dont have two cats the first one is a resinator.
Old Aug 3, 2004 | 01:48 PM
cdogtibby1's Avatar
Default Re: Emissions leak
actually.... the first is the cat, second is the resonator. ya got it backwards NeonOnNos
Old Aug 3, 2004 | 01:56 PM
Glock33's Avatar
Default Re: Oil LIne
I knew it was one of those, Ah I drive american its built into one!!!
