Owned By An Acura Rsx Type S
Old Sep 28, 2005 | 09:44 AM
Screwdriver's Avatar
So, I was on my way to work when I happened to pass a Type S. Seemed modded with basic i/e.
So we went headed on to the neighborhood track which was on the way and which had a controlled, monitored environment. The Acura killed me. I thought I'd atleast get to stay close behind given that I have a 200 lb weight advantage. Guess I was being stupid. The car pulled 4-6 car lengths on me before I gave up.
I have a clogged cat that's probably screwing me over, but I was wondering, would an NA car with the following mods be able to stay close?
AEM CAI
61-65mm BBTB
AIRRAM IM with Spacers
Port Match & Polish Job
Plugs + Wires
1.8 L Cam
Power Pulley set
VHR clutch with forged Flywheel
Ceramic Coated Headers + High Flow Cat
Apexi 2.5 catback
Lightweight 17inch Rims (14 lbs)
Eibach Pro Kit Plus
60 lbs of further weight reduction
Old Sep 28, 2005 | 09:46 AM
wattsup4800's Avatar
yes! my elantra kept up with stock type s
Old Sep 28, 2005 | 09:53 AM
Sorry dude, don't remember what you had on.
This dude has a few small mods on there. Couldn't hear anything forced.
Old Sep 28, 2005 | 10:30 AM
Jaws021's Avatar
Even with those mods, it would be a close one...
Get some tuning, and youll have a better shot.
Old Sep 28, 2005 | 10:42 AM
No Boost.
Just I/IM/E for now.
Old Sep 28, 2005 | 10:44 AM
Jaws021's Avatar
With those mods... you wont stand a chance,... unless they are really not racing.
Add nitrous and youll easily beat him.
Old Sep 28, 2005 | 10:57 AM
The mods I plan are in my first post. Only then will I consider a rematch.
With the mods I currently have, I was 4-6 car lengths behind him.
Old Sep 28, 2005 | 11:41 AM
Zman's Avatar
<div class='quotetop'>QUOTE (Screwdriver @ Sep 28 2005, 10:44 AM)</div><div class='quotemain'>So, I was on my way to work when I happened to pass a Type S. Seemed modded with basic i/e.
AEM CAI
61-65mm BBTB
Plugs + Wires
1.8 L Cam
Power Pulley set
Apexi 2.5 catback
Eibach Pro Kit Plus
For an NA application, I think you should go for these mods:
AEM CAI
61mm BBTB
Plugs + Wires
1.8 L Cam
Power Pulley set
Apexi 2.5 catback
Eibach Pro Kit Plus
Lightweight 15 inch Rims (9~11 lbs)
17" will hurt your perfromance, even though they are "light" and VHR clutch wont help too much, I don't think you really need the clutch since you are not turbo and won't be making more than 150~160 WHP which the OEM clutch can handle well.
Invest that money into the REAL Ecu-Cam combo, or better yet put 1.8 pistons and GK gasket too, I think with that and weight reduction you could have a chance at least to stay close. But ecu tuning is critical for the mods you will need to achieve that.
Old Sep 28, 2005 | 12:04 PM
OdessitPashka's Avatar
With a good driver those cars are pretty quick. I never raced one or seen any at the local track, but as far as I know and have seen few videos they run low 15s bone stock, maybe even high 14s. Add a few little things and you got a solid 14 second car.
They are also really really good from roll races once they are in their v-tec range.
