oil control
Old Jun 10, 2013 | 01:47 PM
J-mega's Avatar
Vehicle: 05 Tiburon 4 cylinder
Default oil control
Is the stock oil pan provide good oil control for autocrossing? I know if I am going to go road racing I should probably get a baffled oil pan, but for now I just want to autocross. Do I need to overfill? I dont want to blow my engine because of oil starvation.
Old Jun 10, 2013 | 01:54 PM
i have NEVER heard of a beta engine dying from oil starvation.
Old Jun 10, 2013 | 05:40 PM
Tak82's Avatar
Vehicle: 1997 RD 4-door
the oil pan on hyundai beta I and II's have a deep yet narrow boxed oil sump so enough oil doesn't slosh enough to one side to cause the oil pickup tube to pick up air..
opposite example..say a dodge neon with a shallow yet very wide pan length..good example of oil sloshing to one side enough to starve the oil pick up tube..<< not good design, being low on oil is imminent to engine failure.
probably the only time oil starvation could occur is if you take the car out to the track and don't check the oil level.
Old Jun 10, 2013 | 05:47 PM
I have seen it cause issues, although not nearly as often as the Alpha or Delta.
Run a half a quart overfilled and you should be fine as long as you don't have slicks and stock suspension.
