Gtech Results
Old Jun 17, 2005 | 11:29 AM
brian01tib's Avatar
i just got a gtech, I have a cai and an exhaust, auto, for the weight I put in 2848 gonna get it weighed soon, this was done in FL prolly 95 degrees out or more, extreamly hot, maybe past 100 definately over 95
83.2 hp @5747
83.9 tq @ 4566
60' 2.772
330' 7.551
1/8 11.493 @ 58.82 mph
0-60 9.884
Ill try to do it when its cool out sometime, I dont know when, its always hot here
Old Jun 17, 2005 | 11:37 AM
11 sec quarter at 58mph?
Old Jun 17, 2005 | 11:38 AM
brian01tib's Avatar
Sorry that was 1/8
Old Jun 17, 2005 | 12:25 PM
2kShark's Avatar
That isn't bad I suppose, even though I can acheive these times easily with just my CAI.
Do you bounce off your rev limiter in first? That can REALLY slow you down. Once while testing my zero-to-sixty run, I revved close to 7K RPMs and then it chirped into the next gear, giving me a 0-60 time of like 11.8.
When I shift around 6,250 or so, my 0-60 time is usually a flat 9.
And I dont really understand your 1/8 mi time...1/8 in 11 seconds, yet you hit 58 MPH?
Bah, autos. They're never consistent. Which reminds me I need my tune up BAD.
Old Jun 17, 2005 | 12:46 PM
brian01tib's Avatar
I didnt rev at all from the start, started from idle, I am going to try tonight afther I get off work but I found some more results I didnt know I stored them
60' 2.761
330' 7.487
1/8 11.334 65.58
1000' 15.427 prolly hit the brakes by then
0-60 9.770
81.8 hp
88.0 tq
for braking its hard to get because it measures from when you start letting off the gas until you stop your acceleration form braking but 53.1-5.5 128 ft
Ill get more times later, BTW the evo got
1/4 14.258 106.53
60' 2.932
1/8 9.731 84.51
0-60 6.275
its stock and didnt launch i too hard but you smell the clutch after the third time or so, usually it only takes one time and you smell it the rest of the day
Ill get some 1/4s tonight B)
Old Jun 17, 2005 | 12:51 PM
2kShark's Avatar
I'm not talking about revving from the start, I'm talking about when you're at WOT in 1st gear does your car go over redline? Mine does.
Hopefully lightweight pulleys will reduce this problem because of the easier shifting.
Anyone know where I can weigh my car?
Old Jun 17, 2005 | 12:54 PM
brian01tib's Avatar
Goes a little in to redline but dosent bounce off the rev limiter, at some gas stations where there are a lot of trucks sometimes have them
Old Jun 17, 2005 | 02:43 PM
shark2's Avatar
Judging by your 1/8 mile time your 1/4 mile is probably 17.5-18.0 sec.
Are you turning off O/D?
Old Jun 17, 2005 | 03:48 PM
brian01tib's Avatar
Well i left OD on but it never went int 4th so it didnt matter, its still really hot Ill do another run tommorow morning
Old Jun 17, 2005 | 04:13 PM
hamhead's Avatar
You do realize that is one of the worst 60' times I've ever seen. tongue.gif Work on launching properly.
And fix your car, cause i got 138whp off a GTech with intake and exhaust.
