Going to Capital Raceway Tonight (1/4 time will be up 9/4)
Old Sep 8, 2004 | 01:55 PM
OdessitPashka's Avatar
Default Re: Pedals
MIA?
Old Sep 8, 2004 | 01:59 PM
supercow's Avatar
Default Re: Going to Capital Raceway Tonight (1/4 time will be up 9/
<div class='quotetop'>QUOTE (OdessitPashka)</div><div class='quotemain'>MIA?</div>
mia - missing in action, hehe ever heard of pow-mia?
prisoner of war - missing in action. it's what the military says when the don't know where the heck you are and they don't have a body. wink.gif
Old Sep 8, 2004 | 02:32 PM
UltraTibby's Avatar
Sorry for the lack of info! I wasn't really MIA just so pissed that I didn't want to post...... Well needless to say I got three runs in. All three were between 17.02 and 17.3 all with a reaction time of between 1.01 and 1.05. And now for what happened. Lets see, first go I was a little shacky it being my first time at the track so I didn't rip the gears too hard. The second time I was pared up with a 350z. I had watched the guy earlier and he really was bad. Well I had him off the line big time and probably would have kept it but...... Oh know where did second go? I threw it into second at 6k rmps and it didn't go into second. Not go in and grind, it wouldn't even go in. So what did I do? I threw it back in first (didn't let it engage) and tried again, still no go. By this time I knew I was going to get creamed so I let the rpms drop down to about 5k (while in neutral) and then the b**** went in gear. Just as it went in gear the 350 went by me. You guys should have heard some of the words coming out of my mouth. The third try I undershifted at 5k rpms into second (which still grinded all to hell cause I shift VERY hard and VERY fast) and so that run sucked ass too.
I dont know what to do. My thoughts were:
- Get a VHR Clutch System
- Get the M&Tec Turbo level gear set (basicly bullet proof)
- Get the M&Tec LSD
- Get the b**** tranny rebuilt
BTW, I didn;t have the CAM installed when I raced it was done the next day. You can feel a noticable difference with it.
Old Sep 8, 2004 | 02:55 PM
tibwrcsbj's Avatar
Default Re: Turbo questions
the first thing you should do is go here :
<a href="http://www.rdtiburon.com//index.php?name=Forums&file=viewtopic&p=5059#5059" target="_blank"><span style="font-size:24pt;line-height:100%"><span style="color:darkred"><u>"Shifting into 2nd..."</u></span></span>
</a>
if that doesn't work then go for the VHR, then the dif, THEN dropp a shit load of cash on the turbo gearing if none of the above worked.
sorry to hear about it......Better luck next time......
Old Sep 8, 2004 | 03:17 PM
UltraTibby's Avatar
Default Re: Calipers
I have The Redline gear oil and the Lucas Stabilizer. It helped for the first 15k miles but now it is back to how it was before. I may replace all the fluids again and try to shorten the cable. Thanks!
Old Sep 8, 2004 | 03:52 PM
tibwrcsbj's Avatar
Default Re: Rear Rotor
oh, and i forgot......there will be a GB coming up for suspension bushings w/ motor mounts as an option coming up......
that may help a little also.
Old Sep 8, 2004 | 09:07 PM
Default Re: Custom Short Shifter.
OY! that's really bad....
you should have imed me and let me know that you were goin, i would have came with you smile.gif
Old Sep 8, 2004 | 09:31 PM
wattsup4800's Avatar
Default Re: FS: Alpine turbo kit
what was the air temp?
approx
Old Sep 8, 2004 | 10:01 PM
Default Wiring harness w/aftermarket bulbs?
I just looked over his mods and saw that he has RAM air intake, im a little concerned about it... could he be loosing a lot of low end and bein so slow because of it?
Ultra, please let me know when you go next time, so I can come with you and drive your car smile.gif
Old Sep 8, 2004 | 10:11 PM
he should be mid to upper 15's
