need to tune your tib?? grab a game boy!!
http://turboxs.com/Dtec/dtec.shtml
The TurboXS DTEC is a revolutionary new product that turns your Nintendo® Gameboy Advance into a programmable, upgradeable, automotive performance tool for tuning, data logging, and diagnostics.
The DTEC plugs into your Gameboy Advance (GBA) and comes preloaded with software that lets you use your Gameboy as a Boost Gauge, Exhaust Gas Temperature Gauge, Air Temperature Gauge and Tachometer. Future plug-n-play sensors will allow everything from Knock Indication to Vehicle Acceleration (ie. G-Force). All sensors are sold separately.
sounds pretty cool to me, my main questions are will the setting your change hold while the gb isn't hooked up and how much is it going to cost? I'm thinking if this would cost ~75 then it would be a awesome deal when you can't touch anything for fuel tuning for less that 200.
Vehicle: 2004 Acura TL
Hrrmmm, I would think that it would just be for monitoring the EGT, A/F and Boost. More like a bunch of gauges in one. I can't see you being able to control the boost threshold from a gameboy.
On the other hand this is really cool. Makes you think about buying 2-300 worth of gauges to monitor these things.
http://turboxs.com/Dtec/dtec2.shtml
sorry the info was over on a link on that first page.
edit: I'm hoping this will be a piggy back ecu we can get for CHEAP!! that just has to be programmed with the gameboy. as well as the guages viewed by gb. I think it would be really sweet.
double edit: oh, btw cyber, I spotted this in my copy of s3 mag. It was in their top 51 new products unveiled at sema.
triple edit!!!:
how does that work? do the setting hold without the axim hooked up. could I just use the laptop?
NEW TXS DTEC!!!
Tuning Ability
The Fuel Tuning!
But this is just the beginning. With the purchase of additional hardware/software packages from TurboXS, you can turn your DTEC into a powerful electronic fuel computer or boost controller. The DTEC fuel computer adjusts the Air/Fuel Ratio by modifying the air-flow meter/MAP sensor signal against engine load and RPM with tuning resolution that is second to none. The DTEC boost controller provides you with total control in either open or closed loop operation, all the while allowing you to display, record or playback any of the input or output signals like RPM, MAF or MAP.
The DTEC is a highly versatile, customizable, upgradeable performance tool that gives you a good excuse to go out and buy yourself a Gameboy. Buy make no mistake, the DTEC is no toy. It is a highly advanced and powerful tool for automotive performance tuning.
The DTEC will begin shipping in late October 2004 so stay tuned!
Tuning Ability
The Fuel Tuning!
triple edit!!!:
QUOTE (javageek)
Yes, it is for real. You can do better with a Pocket PC though. ( Shameless plug for the Axim x3i I have for sale. laugh.gif )
