AC = Defrost??
Yet another question for the guru's out there.
As of recently, we have experienced a cold-snap out here in Saskatchewan (Canada). Now, I turned on the front defrost... but the A/C light came on... is the air conditioning supposed to turn on when I put on my front defrost?? Doesn't that defeat the purpose of it as well? Thinking about it, it doesn't make sense... blowing cold air on a windshield that needs defrost... hrmm...
Or is that just how it works?
AC = Defrost??
2000+ Canadian Tibs are like that.
Yes you can defeat it, but I forgot which wire it was you cut, so you can just control it manually, like the older tibs
But yeah if you want your windows to defrost / defog ALOT faster, use the AC
AC is NOT JUST for cold air, it de-humidifies the air, therefore getting rid of the fog.
It's fine if you have the heat on "HOT" and having the AC on too.
Vehicle: 2009 Hyundai Sonata
ahh, i've been wondering about this too
so does anyone know how to make that manual? (so a/c doesn't turn on automatically for defrost?)
if you use the Defrost on 2nd gens it automatically turns the A/C light on. I believe you can still turn the temp. knob and have it blow heat, but the A/C condenser removes the water vapors from the air and allows the defrost to work. So don't worry about it, it's normal... wink.gif
Well yet again, thank you all very much for your prompt responces. I'm planning my first major trip in my (relatively) new Tib so there were just a few 'quirks' I wanted to work out before hand. Next up... a problem that I may have to bring into the shop. My gasoline gauge doesn't seem to work properly. I fill up and it goes just past 3/4 of a tank... so I never know how much gas I have left in the car!
