? on proper fuel pressure
tibboy316:
I do believe you need a CONSTANT 44 psi
Make sure its 44psi with the vacume line CONNECTED to the FPR.I do believe you need a CONSTANT 44 psi
When you disconnect teh vacume line you should get anywhere between 48-52psi.
You should get a Fuel pressure gauge to monitor your Fuel pressure and to give you an accurate reading instead of just guessing !
