? on proper fuel pressure
Ok, I have a 55 shots on tap and would like to buy a B&M fuel pressure modifier. What would be the proper fuel pressure set up for a 65 shots. It is adustable from 25 psi to 65psi. Random and Red, your 2 cents pls.
when ever you want to use your nitrous it has to be a constant 44psi...get a warblo 255 fuel pump(cheap off ebay,maybe ill sell ya mine if the price is right) and get a fuel reg and get a plate fabricated for it so it fits... then just trun it up when you plan to juice it
thanks. I've always thought that the regulators work on vacuum pressure. why do I have to dial it in. I can't just get out of the car and adjust it when I want to use the gas.
arn you have a ZEX kit... that kit changes your fuel pressure accordinly to the nozzle you have
The stock pump cant take that much, so 65 is your absolute limit
With a ZEX kit you dont need to play with pressure,... the kit does it for you
The only thing you can do is upgrade fuel pump
You can get a cheap 20-50 dollar eclipse turbo pump or you can get the walbro pump
Either one will give you enough for a 75 shot, which is the limit of yor ZEX nozzles
jaws, 65 shots is still ok for the fuel pump. nothing bigger. if I change the pump, what year of mitsu eclipse turbo pump should I ask for? too lazy to do the search. sorry.
and thanks for all the info, Jaws.
also, is it hard to change the pump? any wire cutting if I use either pumps?
[ December 14, 2002, 01:55 AM: Message edited by: arn ]
the fuel pump is very easy to change...its under your back seat...just remove a few screws pull the pump out disconnect 1 hose 1 set of wires put the new pump in a reinsert hose and wire and ur good to go
