Nitrous Oxide (NOS, Zex, NX Express, Venom, etc) This forum is for Nitrous Oxide discussions, and an area for folks to ask questions about Nitrous Oxide and related parts.
50 shot?
Old Mar 1, 2004 | 08:45 PM
97blacktib's Avatar
was wondering if i should spray?
all i got is an intake, full catback and new clutch.
but i like the purge kit, so should i spray or leave it alone?
if i should spray what esle should i get before i get a kit?
Old Mar 5, 2004 | 08:36 PM
sndprssr's Avatar
whether or not you should spray is up to you, but you could do a 50 shot at this point if you wanted to. I have not delt with nitrous on these cars much but you should be safe at a 50 shot although to be safe you might want to use plugs a step colder. If you go any higher(i.e. 75 shot) get an Eclipse (please someone correct me if I'm wrong because I can't remember)GST fuel pump and 2 step colder plugs. Oh...and go with a wet kit, I think NX was the more popular one around the Hyundai community if you didn't already know. Just figured I would add my $0.02 in case anyone actually checked this.
Old Mar 5, 2004 | 08:50 PM
javageek's Avatar
Old Mar 5, 2004 | 09:07 PM
sndprssr, despite how much I like your sig pic, you gotta make it shorter. It's too tall.
Keep it to the size of 10 lines of text or smaller.
Old Mar 5, 2004 | 10:06 PM
sndprssr's Avatar
Ok, my bad...I think I got it fixed for now until I get off this MAC and get to my computer. I hate that Cardomain tag but I can deal with it for now.
Old Mar 10, 2004 | 11:17 AM
JonGTR's Avatar
Go with a NX kit using a 50 shot and 1 step colder NGK's. That should be all you need to get going. Don't worry about a 50 shot blowing your motor.
You also don't need the purge kit. It's a ricer addition until you start spraying a 100 shot.
Old Mar 10, 2004 | 01:31 PM
cdogtibby1's Avatar
soo... is a 50 shot a good mod for a car or is it something only for serious racers? i've thought about that as an addition but i was too scared of blowin something up
Old Mar 11, 2004 | 06:19 AM
JonGTR's Avatar
Unless you continuously screw up and run a 50 shot without somehow adding fuel along with it, you're not going to blow your motor.
A 50 shot is also not a throw you back in your seat power adder, but it is enough to drop your times by one full second. It's a cheap mod for the occasional racer, and an even better mod to get the 4cyl over 500whp.
Old Mar 11, 2004 | 07:37 AM
cdogtibby1's Avatar
soo... on that note, what nitrous system would everyone suggest.. i thought i saw something about nx earlier... but i heard zex has some good stuff too for the tiburon... any suggestions?
Old Mar 11, 2004 | 09:32 AM
JonGTR's Avatar
Personally I wouldn't trust a dry setup like Zex controlling the regulation of fuel. I like knowing that there is 1 fuel and 1 nitrous jet that is permanently set mixing the two together unitl I chose to change them.
