KJB Motorsports
Sponsor:   KJB Motorsports
KJB Motorsports carries many aftermarket parts for different Hyundai vehicles.
http://www.kjbmotorsports.com
Installing Kjb Shifter Bushings
Old Apr 11, 2008 | 04:02 PM
StrikeEagle's Avatar
I got 4 of the same (2 sets of 2 halves), not sure if they were large or small, but they were only about 1in in diameter, about 3/8in thick. I'd ask him, it sounds like you got something wrong...
Old May 5, 2009 | 05:43 PM
lilo shark's Avatar
so how are these working out? i just ordered some over the weekend.
Old May 5, 2009 | 08:38 PM
Larrs's Avatar
Been awhile since I installed these bushing! My original post I had mention I had got 2 different size sets of bushing(KJB sent me GK's instead of RD's). At the time I was working in a tool shop and I just made a copy of the one set out of some delrin that was laying around. I installed both sets of shifter bushing at the same time I'd also installed the aluminum shifter base bushing's and of course a shorty shifter that dropped the shifter by 2". With everything changed over I swear it was like having a brand new tranny, every shift from 1st to 5th was just so sweet. And I also swapped out the clutch and flywheel to a stage 3 racing kit, I'd say it's worth whatever amount of money you need to pay as this car responds like no other car I've ever had.You'll feel difference right away. Larrs
Old May 5, 2009 | 08:42 PM
I must agree. Between these, the shifter base bushings, a QUALITY short shifter, and new OEM bushings in the shifter block, you have a shift sensation that makes just about anyone jealous.
Old May 6, 2009 | 02:50 PM
lilo shark's Avatar
alrite cause the tranny i got fromeric it's hard to get third sometimes just regularly driving so i'm hoping these do the trick.
Old May 6, 2009 | 03:43 PM
<div class='quotetop'>QUOTE (RED ZMAN @ May 5 2009, 10:42 PM) <{POST_SNAPBACK}></div><div class='quotemain'>I must agree. Between these, the shifter base bushings, a QUALITY short shifter, and new OEM bushings in the shifter block, you have a shift sensation that makes just about anyone jealous.</div>
i have to agree...i got both shifter bushings and base bushings...as well as a couple months ago i replaced the spring as well as some of the stock bushings and i freaking loved it...what i will do next time i take my shifter surround off is put some more padding on the spring with some heat shrink tubing you can use for wiring...
