First Oil Change
Old Feb 9, 2005 | 09:54 AM
Black01Tibby's Avatar
Default First Oil Change
This is kinda of a newbie questions, and I am ashamed to even ask. I got my 2001 Tib over Thanksgiving and it is almost time for an oil change. My best friend has a 2002 Celica and it had synthetic oil in it when he bought it. I know you use synthetic oil mostly on re-built or boosted engines so I am wondering if I should even worry about it and just get my standard 10w-30, or if there is something that helps the Tiburon run smoother?
Old Feb 9, 2005 | 10:03 AM
AEMTIB01's Avatar
I run 10w30 Castrol GTX full synthetic, when i change my oil i always dump a quart or two of new oil in the motor and let it drain out the bottom, this seems to clean the motor a little better. and with castrol i swear by that oil, a guy that comes into my work *advance Auto parts* has been running it in his 88 ford Bronco II and he has almost 320 thousand miles on it..
Old Feb 9, 2005 | 10:16 AM
Alex01tib's Avatar
well it wouldnt really matter if you put regular oil into your 2k1 since its stock and pretty new...you can use synthetic if your worried about protecting it.. i go regular in the winter cuz im not driving hard or very ofter for that matter, then synthetic in the summer where i drive hard and often..u can use the lucas additive too...like you said unless its rebuilt or boosted its personal preferance...
Old Feb 9, 2005 | 10:17 AM
AEMTIB01's Avatar
dude i didnt think you could switch back and forth like that??? i was always told that you could go from regular to synthetic but you couldnt switch back
Old Feb 9, 2005 | 10:24 AM
you can switch back. the thing is that you do not want to start using synthetic on high mileage enginesl. the molecules are smaller with synthetic oil, and will start to leak out of any small openings that didnt leak with the regular oil.
Old Feb 9, 2005 | 10:25 AM
Alex01tib's Avatar
<div class='quotetop'>QUOTE (aemtib01)</div><div class='quotemain'>dude i didnt think you could switch back and forth like that??? i was always told that you could go from regular to synthetic but you couldnt switch back</div>
hmm..i never heard n e one say that...hmm... i didnt think there was a problem with tha... any one else have any input? once you go synthetic you shouldnt go back?
EDIT ok so tibby01 posted the same time as me...man had me scared there.. i was like o scat!
Old Feb 9, 2005 | 10:36 AM
CyberShark's Avatar
I heard the same thing, once you go with synthetic, you can't change back..butTibby's comment makes alot of sense
Old Feb 9, 2005 | 10:39 AM
Alex01tib's Avatar
yah all i heard you could go back...i never heard nun of that stuff about the synthetic w. older engines... makes sense learn something new every day
back on topic... its just personal preferance... how many miles on it? sorry if you already said how many but i dont have tim to look i gotta go to class, gotta love Chem!
Old Feb 9, 2005 | 11:29 AM
bryce804's Avatar
i run 5w-30 mobil one synthetic oil. i have 80000 thousand miles. no problems, it accually cured my valve noise.
Old Feb 9, 2005 | 11:40 AM
rallyman's Avatar
It's personal preference. If you want to provide the best protection for your engine and want it to last the longest possible, use synthetic oil. If you don't care or just want to spend as little as possible, use regular mineral oil. Personally, I use Amsoil synthetic which is a true synthetic oil made with PAO's. I have 143,000 kms on my car so far and hopefully it will go two or three times that with no problem.
