AT w/OD Shift Knob
The biggest problem is that you really should find one with 3 wires, most (pretty much all I've seen) have only two. Your overdrive button will not function properly with the 2 wire knobs. Good luck in your quest!
That should be the Mitsu. knob, I know they have stuff for other Mitsu.'s on that site. I got this link from someone in the Mid-Atlantic area. You're right this one does only have 2 wires, so the OD light won't work. But you should be able to tell by feel/sound that you have the OD on or off. I haven't seen any other auto shift knobs w/OD, so the light may be a sacrafice of a aftermarket auto-knob.
