AT w/OD Shift Knob
I know it's been asked before, but what is out there. I searched other posts and only found one.
The biggest problem is that you really should find one with 3 wires, most (pretty much all I've seen) have only two. Your overdrive button will not function properly with the 2 wire knobs. Good luck in your quest!
So anyone know where to get them at. I would really appreciate the help. :D
I think Razo makes an AT shift knob that has an overdrive button. I'm not sure if it's the three-wire version or not, though.
Here ya go...Razo Auto Knob
This is the only one I have seen. A bit expensive though. |
WOW yeah, it looks cool, but it is a little pricey. Can i just get a regular AT handle? What does it do?
It only has two wires. I would not recommend it.
Try searching for Mitsubishi aftermarket knobs, they also have a 3 wire system i believe.
That should be the Mitsu. knob, I know they have stuff for other Mitsu.'s on that site. I got this link from someone in the Mid-Atlantic area. You're right this one does only have 2 wires, so the OD light won't work. But you should be able to tell by feel/sound that you have the OD on or off. I haven't seen any other auto shift knobs w/OD, so the light may be a sacrafice of a aftermarket auto-knob.
