Speaker Install?
Old Feb 26, 2007 | 05:50 PM
gamingdexter's Avatar
hey i'm looking for how to put in new speakers in my car. i'm wondering how to approach this...any ideas??
Old Feb 26, 2007 | 05:57 PM
Tokin's Avatar
Vehicle: 2001 Tiburon
I'll write something up later tonight...I'm in the process of changing mine, but my buddy took off the panels so I'm not sure the minimum required work.
I can tell you now, the fronts are 6.5" and the rears are 6x9".
Old Feb 26, 2007 | 06:45 PM
please leave the DIY section for approved DIYs only.
interior section is fine for things like this...moving.
anywho, its pretty straightforward. take out old ones, put in new ones that are correctly sized. 6x9s in the rear, 6.75" in the fronts. for the rears, stick a screwdriver on the top of the grills and pry down. it will pop right out.
for the fronts, you have to dissasseble the door panel. you should be able to find instructions in the diy forum for that, in the stickied diy listing.
Old Feb 26, 2007 | 08:59 PM
6.5s also work fine up front. ive had them in all my tibs. just have to secure them good
Old Feb 26, 2007 | 09:16 PM
IronFox's Avatar
i know that getting the tweeters out of the dash is a pain but have there been any breakthroughs in doing this without screwing up you dash?
Old Feb 26, 2007 | 09:29 PM
ive had mine in and out a few times. just go at it easy. youll put a small indent in the dash but it will pop out if you are careful
Old Feb 27, 2007 | 06:02 PM
it is foam, and will eventually re-form as long as you dont gouge it up too bad.
