Removing Panel Around The Steering Wheel
Old Mar 26, 2007 | 03:10 AM
prits_uk2002's Avatar
hello does any one please know how to remove the following 3 peice from the dash : the 2 peices around the steering wheel and the peice undr that, the one which is above drivers knees
Old Mar 26, 2007 | 04:49 AM
javageek's Avatar
The steering wheel trim has either two or three screws going up through the bottom. The knee panel requires you to remove the shifter surround and radio surround, then pull the screws from the knee panel and it should be loose. There is one screw behind the dimmer switch as well. After that you need to undo the two screws holding the hood release and the two holding the OBD port.
Old Mar 26, 2007 | 09:15 AM
You could look in the DIY section and see picture by picture writeups on how to get all of this apart in the gauge face DIY.
Old Mar 27, 2007 | 04:38 AM
is there any guide which tells me how to strip the entire interea
Old Mar 27, 2007 | 05:24 AM
yes, webtech.
go into the DIY section and look in the DIY websites thread in the pinned topics area.
Old Mar 27, 2007 | 09:28 AM
QUOTE (prits_uk2002 @ Mar 27 2007, 04:38 AM)
You are kidding me right? I told you, RIGHT ABOVE YOUR POST, where to go and get a picture by picture DIY for taking the entire dash apart.
READ, and go find it.
