Removing dashboard
01Tibby, can you verify that the connections behind the dash for the Rear Fogs are there?
How about the Seat Heaters?
My car's dash is all appart. Where is the switch for the rear fogs / seat heaters normally located? I noticed 1 or 2 extra plugs where the dead switch panel is (left of the steering wheel). Let me know where to look and I will check it out for ya smile.gif
i wouldnt have a clue. you might want to ask madtib though, i gave him the extra wire harness i had.
i dont think the wiring for the heated seats would be anywhere up there, would it? didnt the switch come somewhere on the console for those who got that option?
tibbychick, dont be a wuss. its really not that hard.
Okay, the rear fog light harness connector SHOULD be on the left hand side, somewhere near the front foglight connector.
I was asking about the Heater plugs because I know you've had your seats out, figured you may have looked down there.
QUOTE (tibby01)
I'm just afraid that I'll get it all off and then not be able to put it back on again.
its really not that hard the only problem i had takin it off was i needed to disconnect the speedo drive in order to remove it..but i think tibs have a electric speedo
here is a basic list of tools i used
10mm socket
extension
phillips head
i think 40torx in order to remove the steering wheel
steering wheel puller
white out to align the teeth later on for the steering wheel
i think a 22mm and a extension for removal of the bolt that holds the steering wheel and a breaker bar
10mm socket
extension
phillips head
