radio,dome light,clock fuse, where?
I was helping my friend to install a sub woofer. I accidentally shorted out the yellow power lead to ground while searching for a switched supply lead. The radio, dome light and the clock don't work now. I don't see any blown fuse in the relay box by the engine or the fuse box underneath the steering wheel. Where else can this fuse located? Are there another fuse box that I missed?
Thank for your help
Kai
Thank for your help
Kai
http://hmaservice.com/webtech/iindex.asp?i...1484#_394881484
use the link above. It could be fuse #6 (the 15amp fuse right under the 30amp fuse, on the left side). The box loacated in the floorboard.
Does the head unit have any power?
Thanks for all the replies. I just called my friend to check that fuse. He told me he already fixed it. it was fuse 18 inside a can, he had to open up a fuse holder box to get at the fuse. That was why we couldn't see any blown fuse.
