Radio Doesn't Work
Old Sep 20, 2005 | 06:23 PM
Black01Tibby's Avatar
My radio won't turn on, and when I checked the fuse box I didn't see anything labled 'Radio". Does anyone know which fuse it might be or if there is some other reason maybe that my radio doesn't work?
Old Sep 20, 2005 | 07:57 PM
fuse on back of radio, fuse number 9 i believe.
check the owners manual, it will be in there.
Old Sep 20, 2005 | 08:05 PM
tanc's Avatar
Vehicle: 1997 Tiburon
Check the fuse in the engine bay. It's labeled AUDIO/ALARM something along those lines.
Old Sep 20, 2005 | 10:07 PM
I checked the fuse on the back of the radio and the one in the engine bay..both of them are ok.
Tibby01-by fuse number 9...did you mean fuse number 9 in the fuse box in the cabin?
Old Sep 20, 2005 | 11:58 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
The easiest - check all fuses. Just pick up a multimeter, on each fuse there are 2 small holes for multimeter contacts(pins). So you can check fuse without taking it out.
There are two fuses for radio:
under the dash fuse #14:
1----9
2---10
3---11
4---12
5---13
6---14
7---15
8---16
under the hood:
fuse................................fuse
====== yellow connector======
Xradio fuseX..... lamps fuse
not used...................... lamps fuse
Old Sep 21, 2005 | 12:06 AM
Ok, well I check fuse #14 in the cabin and it was fine as well. So, anyone have any ideas as to what might be the problem?
Old Sep 21, 2005 | 01:57 AM
Dmitry's Avatar
check if your radio gets 12V first, this way you will know what is faulty.
Old Sep 21, 2005 | 01:29 PM
How do I check that? Sorry..kind of a noob question, I just haven't experienced a problem like this before.
Old Oct 2, 2005 | 08:58 PM
ironh19's Avatar
if its an aftermarket radio I recommend checking the wiring for any lose connections. Check your ground and all that other good stuff.
