Question about roll cages
Old Nov 24, 2010 | 11:50 AM
superwoo's Avatar
Vehicle: 00 Elantra
Default Question about roll cages
I know roll cages are best used if they are welded to the body but I was wondering if bolt in cages will work well also.
Old Nov 24, 2010 | 12:13 PM
If you would survive the crash, yes. If you wouldn't survive the crash, the bolt-in may fail sooner if not properly secured . . . but you would be dead by the time your roll cage goes flying loose, so don't sweat it.
Do sweat the mounting of your seat belts. If you get a 4 or 5 point belt setup, make sure the shoulder parts are secured to something higher than your shoulders.
Old Nov 24, 2010 | 12:31 PM
tanc's Avatar
Vehicle: 1997 Tiburon
Actually stocker is should be shoulder height or 4 degrees below as per NHRA rules.
Old Nov 24, 2010 | 09:28 PM
4º != bolted to floor
Old Nov 25, 2010 | 01:16 AM
tanc's Avatar
Can't be bolted to the floor. I'm talking about 4* from shoulder height to rear bar.
Old Nov 26, 2010 | 09:16 AM
Rereading my 1st post in this thread I was wrong so to me on that. I never read the NHRA rule book so I never heard of 4º down, but if I was to put a harness on my seat the belts would be straight back, to a bar immediately behind the seatback. A very slight down angle makes sense because you won't be staying as high in your seat in a crash. An up-angle lets you up off your seat. My point was bolted-to-the-floor is straight-up dangerous!
