passenger seat to driver seat modification
Old Jan 5, 2014 | 05:51 PM
bigfishmoney's Avatar
Default passenger seat to driver seat modification
is it possible to remove the track from the passenger seat on a 2001 Tiburon to the drivers seat by chance?
Old Jan 5, 2014 | 06:35 PM
Given enough time and money, you can do pretty much anything. You can use seats from other cars, even, provided you can make adapters/mounting brackets. The RD's seats come out with four bolts each, fold the seatbacks forward and lean them back upside-down and compare. You can know for sure if you can swap them across in under a half hour.
Provided you still have both seats with their brackets.
Old Jan 5, 2014 | 07:56 PM
tibbytib's Avatar
If I remember right, the seat belt will be on the wrong side. Not sure if you can change that. I swapped my leather skins from passenger to driver to get more even where on the seat. The bolsters were wearing out on the drivers side. It wasn't hard. Took about 40 minutes.
Old Jan 5, 2014 | 08:57 PM
Don't think the seatbelt can be swapped but I may be wrong. If it can't, you could always install a harness bar with some 4 points.
