paint vs dye?
paint vs dye?
I know everyone will rip on me for this becasue of all the interior dye threads but can anyone tell me what should i use to paint my interior, dye or paint? WHat is the best kind? Any good name brands? Thanks
I didnt know there was a dye? Do you have a website? You can dye plastics?....
But here are some cons about paint:
- somtimes sticky
- melts in heat(some)
- unless you are paranoid about who sits in your car, it will look like shit in 2 months.
- somtimes sticky
K, I knew you could dye vinyl, but not plastics(right? I dont see how that could really 'soak' in and dye it)
*BORED*
EDIT: I just searched....It comes in a can. They should make a dye where you could like fill up a tub or somthing with it and actually like soak your material in it, that would be cool.
*BORED*
The SEM dye is the preferred product, and it works VERY GOOD. SEM also makes a good can of textured spray so you can fill in any scratches and such before you paint.
I used normal spray paint (primered first), with engine 500 degree clear coat. It's held up perfectly for over 2 years now. Spray paint can work just fine if done correctly.
