Ok, WTF!!! Urgent!
Old Oct 14, 2001 | 01:42 PM
  #51
WhoopOi's Avatar
Ooooh oooh, what if the wires that I'm connecting to my amp... are touching the frame of the basket??
Old Oct 14, 2001 | 01:57 PM
  #52
ICE3X's Avatar
yeah, that would do the same thing, if your wires are bare wire (no insulation)
Meadville, PA about 1/2 hour south of Erie, PA right of I79
Old Oct 15, 2001 | 02:00 AM
  #53
WhoopOi's Avatar
alright, so what should I do to "insulate" it? smile.gif tape up the basket? I was wondering where ya lived because I know a Meadville a good 30 mins from my house, but you're a good 7 hours. smile.gif My friend goes to Penn State Erie Campus. Oh well... lemme know how to fix it.
Old Oct 15, 2001 | 03:19 AM
  #54
SupraGuy's Avatar
Why tape up the basket, and not the WIRE, which is the source of the problem?
Originally posted by Dan:
For taping... The idea is to prevent any unwanted electrical contact. I'd be breaking out the ohmmeter anyway with the problem you're having, but I've already recommended that... If the speakers WORK when they're not bolted to the frame, then you want to insulate in between the frame and the speaker basket. For this, you cannot use metal screws/bolts to hold it down, or you've just created a path to ground.
You say the wires are connected to nothing. I don't buy it. They're connected to something. Disconnect the wires from EVERYTHING. Check for continuity to ground. Check for continuity between leads.
Both of these would have identified a short to the speaker basket, if you measured it while the basket was in place. I thought that it would make sense to check the fault in the state that it's happening at.
And, for the record, I still don't understand why you're connecting to the spider leads, and not to the speaker wires.
Insulate the speaker wire, using electrical tape, so that it cannot contact the basket. The extra mass where you connect to the spider leads may be weighing down the speaker leads so that they contact the basket. Connect to the speaker wires. Really. If you don't want to damage the factory speaker wires, try something like this:
Using common spade terminals, this can be done, hooking up the amp in parallel with the speaker. Note that this is still a bad idea if your amplifier high level input is 4 ohms.
If the resistance of this circuit is too low, try:
This will not work well, if the amplifier high level input is also high resistance, but it will work better if the amplifier input is low resistance. If the resistance on the circuit is too low, the amplifier may drive it, but at the cost of a reduced lifespan and increased distortion.
[ October 15, 2001: Message edited by: Dan ]
Old Oct 15, 2001 | 12:53 PM
  #55
ICE3X's Avatar
LOL, you are just going to confuse the poor guy with all that series and parallel stuff
(ohms law)
if your speaker wires are bare wire, you probably should get some insulated speaker wire to use.
and instead of just twisting the wire around the terminals or spider leads, like dan said, it would be better just to go to Radio shack and pick up 4 quick disconnect speaker terminals, and use those to connect to the speakers.
Old Oct 15, 2001 | 01:43 PM
  #56
WhoopOi's Avatar
....*homer simpson face*
Old Oct 15, 2001 | 02:45 PM
  #57
Jaws99's Avatar
Either that or take it to circuit city or the shop of your choice and pay $35 to have it done. Never in my life have I seen a bigger problem with speakers, ever.
Old Oct 16, 2001 | 12:35 AM
  #58
SupraGuy's Avatar
I'll second that...
Old Oct 16, 2001 | 01:11 AM
  #59
WhoopOi's Avatar
....true....true......
Old Oct 22, 2001 | 12:18 PM
  #60
Tibbon's Avatar
Vehicle: 2004 Tib - Beta
Hey did you fix the speakers?, you left us hanging. This post was very intense. I was right into it. I could feel the frustration. We have all been there.
