new stereo system ?
Re: Drifting gone wrong? Work Safe
......... but i have to use washers on the screws to hold them into the stock mounting spot because they are still as little too small
Dweet, I just noticed what you said here.If you used washers to space the woofers out away from the window, how are you sealing them? You cannot have space/gap between the woofer and the mounting area(baffle).If so, the back wave of the speaker is allowed to mix with the front wave and this will cause phase shifts. The biggest sign of this problem will be a serious lack of bass.Other signs of phase problems will be images that are 'misplace', along the sound stage.
Re: FS: Oilbank Racing GT front bumper only
Uhm, Madtib.
What did you do to Dweets first post?
Anyways, the fronts are 6.75, not 6.50. You'll notice when you try to put in 6.5's like I did that you have to squeeze the plastic mount in place to get them to go.
Vehicle: 97 Tiburon
Re: Rally Crashes
QUOTE (REDZMAN)
Re: auto tranny problems?
I don't know what the hell happened!! Sorry.I hit the quote button on Dweets post.After submitting, I noticed that my post went under his first. 8O
