mounting amp in trunk
Old Nov 4, 2004 | 09:10 PM
00tibby's Avatar
Default buying new amp....i need opinions.
i want to know how u guys mounted ur amps in the back. i dont really wanna screw them down into the floor if i dont have to so if any one has anything creative. post pics or describe. Note: i like to be different so ill probably change it in some way or another
Old Nov 4, 2004 | 09:17 PM
Default Re: Here's My car
I have not gotten that far yet.. but I was thinking on the back wall between the taillights.
Old Nov 4, 2004 | 09:18 PM
tanc's Avatar
Vehicle: 1997 Tiburon
Default Re: mounting amp in trunk
You can mount it to your backseat, or right on ur sub box make sure u got an alarm system u dont want theifs takin out ur box and having everything already screwed on it. its a jackpot and a target
I have a custom fiberglass enclosure in the trunk and my 2 amp's have there own little display placement.
Old Nov 4, 2004 | 11:25 PM
MADTIB's Avatar
Default Re: FS: stock rd1 tail lights
I have mine mounted to the back of the left half of the rear seat.The amp I'm using looks awesome, so I felt I did not need to do anything too custom for it to look good.
Two things here:
(1)If at all possible, DO NOT mount the amp(s) horizontally.Especially if they are hi power.Amplifiers dissipate heat best if they are mounted vertically.
(2)If you do mount to the rear seat back, be aware of the fact that the metal in the seat pan is chassis ground.The amplifier WILL become part of a ground loop and allow noise into the system.Even if you leave the carpet on the back of the seat, the amp will become radiated via your mounting screws. The best way to bypass this is to take the seat apart, cut out a chunck of the metal, and replace it with a piece of particle board or MDF.That way, no part of the amp is in contact with chassis ground.You will be totally isolated at that point.
Old Nov 5, 2004 | 07:09 AM
Default Re: blue door courtesy light
You know.. I had that thought.. cutting into the back of the rear seat and mounting an amp kind of flush.. maybe with a fan in there to help the heat problem.
Old Nov 5, 2004 | 10:31 AM
MADTIB's Avatar
Default Re: Gauge Group Buy GREAT DEAL from Splitfire!! NOW TAKING M
Don't necessarily need a fan.That's just extra stuff that probably isn't needed.
Old Nov 5, 2004 | 01:14 PM
00tibby's Avatar
Default FS: Alpine Head Spacer for beta engines $110 shipped!
cool ideas, and thx for the advice madtibs.....anyone got some pics though. i would like to stay away from cutting into the seats if possible....
Old Nov 5, 2004 | 06:56 PM
you don't necessarily need to cut into the seats.. you could always mount covered particle board to the back of the seat and then screw the amp to it.
Old Nov 5, 2004 | 07:39 PM
MADTIB's Avatar
Default Re: raffles
Yeah, but then you have an ugly board bulging out of the back of the seat.Even if you wrap the board in carpet first, it'll still look like hell.
Old Nov 6, 2004 | 03:59 PM
Default Re: need some help guys!
well.. I was sort of thinking along the lines of covering the entire back of the seat in the board... then it would not look that odd..
