Mounting an amp question
Old Jan 19, 2012 | 01:22 PM
hornet's Avatar
Vehicle: 2001 Accent
Default Mounting an amp question
I have seen people mount their amps to their back seats so that the amp is right up against the seat. I have seen others mount their amps with what looks like spacers between the amp and the seat so theres air flow between the 2. Where do I get those little spacers and is there an actual technical term for it?
Old Jan 19, 2012 | 07:55 PM
Red Raspberry's Avatar
Don't know exactly what type you want but they are called stand offs. Some have a threaded insert all the way through, some have a stud and a threaded insert.
Here's a threaded rod coupling nut. 1/4" -20 should do the job and available at about any hardware store.
Old Jan 19, 2012 | 09:54 PM
songee623's Avatar
Vehicle: 2005/hyundia/elantra
i used extra nuts i had since i had carpet on my amp board they gave it just the right lift and cant be seen.
Old Jan 20, 2012 | 04:25 PM
holeshot69's Avatar
Vehicle: 1998 Tiburon
Buy a 4awg kit with it? Use some of the left over insulator from over the wire.
