Leds And Resistors
Old Jul 24, 2006 | 02:31 PM
what is the best way to connect the led to the resistor and then connect the resistor to the power wire? I looked and didnt see any advice on this. Thanks
Old Jul 24, 2006 | 02:34 PM
sjl01's Avatar
On the ones i've done , i soldered the resistors to the led( onto the long leg) and soldered to the wire as well then used heat shrink tubing to cover the connections.
Old Jul 24, 2006 | 03:54 PM
hmm my solder wouldnt hold it. ill try it again
Old Jul 25, 2006 | 10:36 AM
sjl01's Avatar
try putting some flux on the parts you soldering, it deoxidisese (cleans) the parts your soldering ,so you should get a better weld (stronger).
hope this helps.
Old Jul 25, 2006 | 02:05 PM
Do this:
you can hold both the LED and resistor in 1 hand and apply solder from the other side if you don't have a camera in your hand
Also, make sure you use some rosin core solder, you won't need flux if you use that. Also, make sure you are heating up the metal and not the solder
Old Jul 25, 2006 | 03:39 PM
alright thanks for the tips
Old Jul 25, 2006 | 08:51 PM
btw... i made that joint huge for the picture, usually i only leave about 1-2 mm of excess off of the LED for soldering.
and if you solder it onto the short leg, then you have 2 long legs to work with and trim down if needed, if you solder onto the long leg, you've got 1 long leg.
Old Jul 25, 2006 | 09:04 PM
FlyRyde's Avatar
I'll post a nice how too on FlyRyde with video to show you the technique I've been using for the past 3+ years in all my products.
Old Jul 25, 2006 | 09:53 PM
^awesome chris. hit me up for some hood cash when you know whats up
