Kicker Sub
only half the sticker is there and it says the exact same as the speaker. i put it in that box just to work the sub a little since ive had it in storage. Brooke any idea on a cheaper amp that will power the speaker?
you could use something like this.
Or you could stick with your current amplifier. Actually, your current amplifier is overpowering your sub by 20W. If you have just one subwoofer, then you should bridge your amplifier into 1x420w. It will power your speaker just fine. I wouldn't recommend changing it at all, usually manufacturers give at least +/- 10% leway when they design specs.
sorry, im becoming slow with things around here, but 420x2 is bridged power? are you meaning hooking up both sides of speaker up each side to one of the bridged channels (1+2 and 3+4).
