Kicker Sub
Old Feb 25, 2008 | 12:38 PM
tib _500's Avatar
i have a kicker comp vr that i cant find any information on
the only information i have is it is a 12in Kicker Comp VR and im almost positive it was 1000W max
ill have a pic up shortly but it is not either of these
any help greatly appreciated
Old Feb 25, 2008 | 12:43 PM
Caj Darkmoon's Avatar
Hahahaha, also not any of these three:
Old Feb 25, 2008 | 03:05 PM
brooke_ox's Avatar
The first picture of the Comp VR(Which is 3-4yrs old) was 800W max and 600W RMS.
Ill check back for correct picture to see if I am of anymore help to you.
** I JUST ASKED MY MANAGER (I WORK AT A CAR AUDIO SHOP) AND WAS TOLD ALL OF THE 12" KICKER COMP VR WERE RATED AT 800W MAX AND 600W RMS. **
Old Feb 25, 2008 | 04:03 PM
tib _500's Avatar
Bump: photo uploaded
Old Feb 25, 2008 | 04:27 PM
Tib001's Avatar
I think this is right. Let me know if it is the wrong model. The site is strange but has the specs for it.
Old Feb 25, 2008 | 04:35 PM
tib _500's Avatar
that might be it for some kicker sub but i don't know if thats the specific one for this one.
Old Feb 25, 2008 | 05:23 PM
Tib001's Avatar
I found that through this page The kicker sub looks the same as your pic and that was what I was going by. I can't say it is exactly the same though as yours seems to be an older model but the pic on the site looked similar to yours.
What did you need this info for? Are you puting it in your car or possibly selling it?
If you are putting it in your car what amp are you going to use?
Old Feb 25, 2008 | 06:25 PM
tib _500's Avatar
o ic ive got this amp with these specs ive had it for awhile
BOSS REV-9651
4-Channel MOSFET Power Amplifier
• Power RMS (4 Ohm):150W x 4
• Max Power (2 ohm): 250W x4
• Signal to Noise Ratio: 104 dB
• Bridged Power: 420W x 2
• Tri-Mode
• Built-in X-over: hi&lo Pass
• Bass Boost +18dB
• Inputs: Line Level
• line Out
• T.H.D.: 0.01%
• Dimensions (WxHxL): 10" x 2-1/4" x 15-3/4"
o and im gonna go ahead and move those speaker specs found to here
Model C12vr
Size (IN., CM) 12, 30.5
Impedance (OHMS) 2DVC, 4DVC
Max Rec Amplifier Power (WATTS PEAK) 800
Maximum Amplifier Power (WATTS RMS) 400
Sensitivity (dB 1W/1M) 86.7
Frequency Response (HZ) 25-500
Mounting Depth (IN., CM) 6, 15.3
Mounting Hole Diameter (IN., CM) 10-15/16, 27.8
Min Rec Sealed Box Vol (CU. FT., LITERS) 1.0, 28.3
Max Rec Sealed Box Vol (CU. FT., LITERS) 4.6, 130.3
Min Rec Vented Box Vol* (CU. FT., LITERS) 1.75, 49.6
Max Rec Vented Box Vol* (CU. FT., LITERS) 2.25, 63.8
Old Feb 27, 2008 | 11:15 AM
brooke_ox's Avatar
I work in a car audio shop that was a HUGE kicker dealer when the Comp VR's were big.
It will take up to 800W RMS.
That amp is a little small for it, but it will work fine!
Old Feb 27, 2008 | 03:49 PM
tibbymat's Avatar
pull the sub out of the box and on the magnet there will be a sticker with the model number of the sub... google it and there ya have it!!
