Installing Remote Start
Old Mar 21, 2008 | 04:33 PM
mb499's Avatar
I am definitely interested in alarm GB, not sure about remote start, not really my thing.
Do you by chance sell door poppers? I can't think of the right word, basically handle-less doors you just push a button and they open.
Old Mar 22, 2008 | 08:33 PM
gophins349's Avatar
tibbymat
could you get me a price on the model....3271M-2w
thanks
Old Mar 22, 2008 | 08:54 PM
tibbymat's Avatar
anyone lookin for an ultrastart, titan, or polar start remote starter or alarm, please PM me so i have a reminder and something i can remember to check on!
pm me that model gophins
and that 1256 i believe i can get it shipped out to you at $150
Old Mar 30, 2008 | 12:06 PM
gophins349's Avatar
ok im doing alot of research because i am going to install this on my own. i am having problems locating the info i need.
i am looking for the posts about the wiring color code... i know i saw it on here somewhere but i cant find it.
if someone knows where it is can you please show me thanks.
Tibbymat ill get back to you monday sometime
thanks for all your help so far
Old Mar 30, 2008 | 05:29 PM
tibbymat's Avatar
ITEM WIRE COLOR POL LOCATION INFOTECH # PHOTO NOTE
12 VOLTS yel/blk to blue + ignition harness Notes: The plug is below the cross member beam under the driver side dash.
STARTER 1 yel/red to gray + ignition harness
IGNITION 1 blk/wht to brown + ignition harness
ACCESSORY 1 red/wht to grn/wht + ignition harness
ACCESSORY 2 wht/blu to pink + ignition harness
POWER LOCK add actuator in drivers door
POWER UNLOCK same
PARKLIGHTS POSITIVE green/white gray 20 pin plug, pin 11 Notes: The plug is below the cross member beam under the driver side dash.
PARKLIGHTS NEGATIVE red/black headlight switch
HEADLIGHT blue/black - headlight switch
BRAKE green + brake pedal switch
DOOR PIN green/white - white 20 pin plug, pin 12 Notes: The plug is high in the drivers kick panel.
TRUNK PIN blue/white - white 20 pin plug, pin 16 Notes: The plug is high in the drivers kick panel.
DOMELIGHT SUPERVISION use door trigger
TACH white blue 20 pin plug, pin 1 Notes: The plug is just below the cross member beam under the driver side dash. Can also find tach at the ignition coil on the driver side of the engine, use either the green or white wire.
VSS yellow/black data link connector Notes: The data link connector is under the driver side dash below the steering column.
WINDOWS
LEFT FRONT UP/DWN blue - brn/blk A drivers window switch
RIGHT FRONT UP/DWN blue - brn/blk A passengers window switch
SUNROOF OPEN/CLOSE yel/blu - blue A sunroof motor
HORN pink/white - steering column
WIPER red (l), green (h) - steering column Notes: These wires are high current negative.
RADIO 12V red/white + radio
RADIO GROUND black - radio
RADIO SWITCH orange + radio
RADIO ILLUMINATION green/white + radio
FACTORY AMP TURN ON
POWER ANTENNA
LEFT FRONT SPEAKER yellow - black radio
RIGHT FRONT SPEAKER orange - green radio
LEFT REAR SPEAKER brown - white radio
RIGHT REAR SPEAKER white - brown radio
Old Mar 30, 2008 | 05:50 PM
gophins349's Avatar
tibbymat you are the man. but i was looking more in to the clutch switch.
i am going to do what tibby01 did with the magnetic read switch, i just dont know which side of the switch to put the starter wire
i was on hma and looking at the starter wire schematics and did not know what the BR/B wire is. that is more of what i was looking for. the color codes
Old Mar 30, 2008 | 05:53 PM
tibbymat's Avatar
i can find out the clutch bypass tomorrow.
Old Mar 30, 2008 | 06:03 PM
gophins349's Avatar
another question what does it mean when it says yel/blk to blu?
i get that it is a yellow wire with black strip
and a blue wire
but what does it mean when it says "to"?
Old Mar 30, 2008 | 06:17 PM
tibbymat's Avatar
it means that from the ignition to a harness is one color and then it plugs into another harness where the wires change color.
Old Apr 6, 2008 | 01:54 AM
fury's Avatar
first off, check out my post in Gripes and Complaints titled, "My car crashed". My remote starter had a mechanism for determining if it was in gear or not. That failed, about 2 weeks ago, and I'm still getting it fixed ($1500 later). If you're driving manual, think about that. Definitely have some other form of backup for determining whether you're in gear, or not; magnetic reed swtich, for ex.
QUOTE (gophins349 @ Mar 18 2008, 12:40 PM)
also how do you bypass the clutch switch? do you just wire around it as in just take the switch completely out?
Here's the diagram I used (Diagram /D):
http://www.velocitymotorsport.com/images/i...l_notes/107.jpg
If you have any questions, let me know.
