I'm sick of this damn dash
Old Jul 1, 2004 | 07:47 PM
Arch93086's Avatar
What could it be? If the crimping was bad, it wouldn't work once and then not work again would it? I crimped it the best I could. I'm not professional, but I can crimp all right. (I guess)
I wouldn't be surprised if it was the wires, I f*** up everything.
Old Jul 1, 2004 | 11:46 PM
if the crimp is bad, it could be the slightest vibrations that cause the connections to turn from good to bad.
Old Jul 1, 2004 | 11:54 PM
MADTIB's Avatar
Like Tibby01 says.If your crimps are bad,you should be able to jiggle the wires and have it cut off/on.
It could be the xformer.There are more electronics in there then just a xformer.You also have a DC-DC power supply,since a xformer can not pass DC current thru it and DC is what you get from the batt.So,there has to be a power supply to convert DC to AC,then rail the voltage/frequency up from there.
Maybe you didn't want to know that much about it, but I wanted to make sure it's understood that there's a little more going on in there.So,yeah, check the crimps and see if you can make the light cut on/off.If not,then you probably have a dead xformer.
*DOUBLE POSTS OWN ME!!!*
Oh.....................you might also have a problem with the dimmer.I'm on like my 3rd one.They are pretty sensitive.Make sure you do not connect the switch when the parking/headlights are on.You'll zap that thing real quick!!
Old Jul 2, 2004 | 06:48 AM
Arch93086's Avatar
QUOTE (MADTIB)
Just for arguements sake, 02.gif say I did connect it while it was on, would it never work again, because I did connect it while the lights were on.
