Illuminated Ashtray Led
Old Nov 7, 2008 | 06:24 PM
Sauga's Avatar
From: Mississauga, ON, Greatest Country on Earth :p
So the other day I had my centre surround pulled and I realised there was an LED in the ashtray. bigeyes.gif
This was intensely satisfying considering I had already planned out and bought the parts for a custom ashtray lightup dealie (technical term).
So my question is, anyone know the specs of the stock ashtray LED and how to go about replacing it? (with a sexy blue one of course)
Old Nov 7, 2008 | 07:42 PM
I made my own custom solution. grab some random plastic, and some LEDs,then epoxy that sucker together. You don't have to look at it. There might be a better way if yours came with a light back there to start with. That's how I did my ashtray and lighter.
Old Nov 7, 2008 | 08:33 PM
It's not a LED, it's a 73/74 size bulb if I remember correctly.
Old Nov 7, 2008 | 09:56 PM
StrikeEagle's Avatar
^^^ Yup. Not sure of the size, but it's definitely a bulb. Either that or someone's beaten you to the punch. Don't forget to put the resistor in there.
Old Nov 8, 2008 | 01:10 PM
Sauga's Avatar
Thanks, I'll update when I get around to ordering/installing them.
On a related note, are these 73/74 dash bulbs the same size as the ones used to illuminate the guages/dash accessories?
If so I'm going to look into a bulk pack and continue the blue theme I'm going for.
Old Nov 8, 2008 | 10:27 PM
Yes. ONly problem is you need a 90 degree bulb for the lighter light, when you take it all apart to look at it, you'll see why.
