I got a small problem - please help
NO Guys, I have been trying to find pictures online to show you where they are supposed to be mounted and that's where I want them...
Let me see if I can show you how:
1- you guys know your rear seat belts right??? in the middle are the 2 clickers and on the sides, you find the bets themselve??? correct
2- ok, if you take off that bench seat, under there you will find where those 2 clickers are bolted to the car... (those are 2 holes right there), and you will also see where the belts are bolted to the car at the bottom (those are the other 2 holes)
3- Well how the harness should be mounted is, that you criss-cross them, and one goes in the middle hole, and the other in the side hole... same for the other side...
I hope I explained that a little better...
#1. Modify your current amp setup to allow the harness to pass thru.
#2. Plan you "new" amp setp to allow the harness to pass thru
#3. Install a new roll cage and amp setup that gives the belts something to attach to.
#4. Just bolt them to the floor, with some reinforcement.
#5. God, if you go with THIS setup, you'll never be able to see out of your back window or rear view mirror! *LOL*
[ January 09, 2003, 11:40 AM: Message edited by: Random ]
