Help.... Speedometer Not Working
Old May 27, 2006 | 06:36 PM
pr00f568's Avatar
I was resetting my gauges. Everything was looking good till I turn the car on. The tact is working fine. The speedometer is sticks to zero till i hit a bump then it goes the the right speed , then sticks.what could be wrong. I was looking at kspec at the maxtrim gauges, is that a whole gauge cluster or just the face?
Old May 27, 2006 | 09:03 PM
KayJai's Avatar
What do you mean you were "reseting" your gauges,...
If you took the needles off and put them back on,... the speedo needle is on too tight / close to the gauges
Old May 27, 2006 | 09:48 PM
pr00f568's Avatar
when i turn my car on the tach would jump to 3k rpms and the speed would jump to 10mph. So i took the needles off and put them back on...
Old May 27, 2006 | 09:50 PM
KayJai's Avatar
Have you touched the needles before this?
Did you change your gauges or pull the needles off before?
