help me with my indiglo gauges please
Old Oct 26, 2001 | 12:59 AM
TJ Strickland's Avatar
Default help me with my indiglo gauges please
i bought some indiglo guages but when i put them in my needle wouldnt go over them. Can someone please tell me how i can put them in my car and have my needle go over the guages this is the 2nd set that hasnt worked. please help me
Old Oct 26, 2001 | 01:32 AM
yamaneko's Avatar
The indiglo gauges from APC are only made for the 2000-2002 Tiburon, not the 1999. YOu can modify them though to fit...
Old Oct 26, 2001 | 01:44 AM
these arent apc there aerodynamic and they fit fine... the needle just doesnt go up on the rpms and mph. how can i get the to stick down so the needle goes up with out gettoing stuck and not going anywhere
Old Oct 27, 2001 | 08:21 AM
TJ
If I understand this right...the gauges fit, but the speedo and tacho needles stick/stop or don't go all the way up. Right?
if so, just loosen the needles. Pull them back out about 1/8" to 1/16", that should free them up and allow them to do the full sweep.
[ October 27, 2001: Message edited by: Random ]
Old Oct 27, 2001 | 03:04 PM
if i pull my needles out wont that mess up my calibration. i heard it would mess it up and i would have to get calibrated again or possible new needles.
If i pull my needls out a little bit will it mess up anything????????
Thanks
TJ
Old Oct 27, 2001 | 03:14 PM
As long as you don't pull them OFF, you should be fine. You just need to give the needle more "clearance" to sweep around without hitting the new thicker gauge faces. So you just need to pull them back a tad, about 1/16" to 1/8". If you go too far the needle will come off and yes, then they might have to be recalibrated.
How did you calibrate your needles after installing the gauges in the first place?
Old Oct 28, 2001 | 12:10 AM
ok thanks a lot
