Help With Angel Eyes
Old Mar 2, 2006 | 05:43 PM
tibcr's Avatar
Thanks man, as I am no expert on this issue I made a drawing to see if I got it right
Is that correct this way? The resistor goes on the negative wire? What if I use like a 560 Ohms, wouldn´t that be better?
Thanx
Old Mar 2, 2006 | 06:04 PM
no man... like this.
You can lengthen the wire and put the LED in your grill or something.... maybe illegal in your state.
To make them cover a larger area, file down the tip until it's completely flat, not rounded at all.
Old Mar 2, 2006 | 06:10 PM
you have the leds in parallel in that drawing. you want it like this....
12v-resistor-anode led1
cathode led1-anode led2
cathode led2-ground
anode= +
cathode= -
Old Mar 3, 2006 | 07:53 AM
tibcr's Avatar
Great, thanks a lot DrivingTiburonNaked and Tibby01, now I got it. I´ll pop my headlights open for the fifth time on sunday (these damn things now open up almost by theirselfs) smile.gif and will do that, hope it´s the last time for a long, long time.
Thanx buddies
Sorry to bother again, I fount this resistor calculator on http://led.linear1.org/led.wiz and if you look at the drawing:
Solution 0: 2 x 1 array uses 2 LEDs exactly
The wizard says: In solution 0:
* each 470 ohm resistor dissipates 188 mW
* the wizard says the color code for 470 is yellow violet brown
* the wizard thinks 1/2W resistors are needed for your application Help
* together, all resistors dissipate 188 mW
* together, the diodes dissipate 128 mW
* total power dissipated by the array is 316 mW
* the array draws current of 20 mA from the source.
you can see that they recommend to put the resistor at the end on the negative wire, now I am confused again. And I should use a 1/2W resistor not the 1/4W. I am really sorry for all this questioning but I am just tired of doing things wrong and opening my headlights, I want it done and get over with it.
Thanx
Old Mar 3, 2006 | 11:30 PM
You may want to consider using MORE resistance as it is the hottest area of the vehical people usually put LEDs. Like you could add an extra 50-100 ohms for $1 at radio shack and still have 3 resistors to spare. It's a trade, brightness for longevity. You could run 2 leds to compensate, just file them down on the sides and stick them together.
