Halos around my Sub
Old Nov 21, 2003 | 06:30 AM
Ok.. I am definatly going with the Polk momo speakers.. but, as I am building a custom enclosure (as soon as I buy them, after the new years) I was thinking a halo around the sub.. I was going to sink it back some into the housing, so that the halo could sit flush and shine light onto the sub.
Can it be done in Green?
Old Nov 21, 2003 | 08:16 AM
Solo-Baric's Avatar
screw that. make a part of the box out of plexi and put a green neon inside the box.
Old Nov 21, 2003 | 06:01 PM
Default FS: CUSTOM dual 12 inch subwoofer box made JUST for the RD2
Actually... I did some thinking on it today... here is what I am going to do.. Plexi UNDER the wood of the box... with the Sub mounted to the underside of the plexi (Probably a sandwhich of wood, plexi, and then wood.. with an array of LEDS arranged to light up the plexi from WITHIN the plexi itself. Plastics like plexi and Lexon have a unique property where light that is originated along the length of the material (as opposed to passing through from clear side to clear side) will follow the material until it hits an obstruction. Just like it does in Fibre optics.. so.. the edge around the sub should glow with a nice even hue from within.. with little light lost elswhere.
Old Nov 21, 2003 | 09:34 PM
Thortib's Avatar
I really like you're idea. I bet it'll look awesome. But after I read it I found this http://shop.store.yahoo.com/mobile-emotion...inbluneons.html I like you're idea better, but I thought it might help you somehow
Old Nov 22, 2003 | 09:47 AM
Those are VERY cool looking... but I like doing custom work
For the link impared
Old Nov 22, 2003 | 01:22 PM
Thortib's Avatar
whatever you do I think it would be awesome if you hooked up the lights to a pulser.
Old Nov 22, 2003 | 05:14 PM
Solo-Baric's Avatar
Default REDZ? REDZ? Where is he? *REDZMAN Update 2*
just hook the lights up to the sub terminals.
Old Nov 23, 2003 | 12:25 PM
ok... this is new to me.. hook the lights up to the terminals?
Old Nov 28, 2003 | 02:13 PM
I'm hesitant on suggesting you do this. Personally, I think it would look like a cheap audio setup from Wal-Mart... but as long as you make it look clean, that's all that counts.
Old Nov 28, 2003 | 06:00 PM
clean is what it is all about. No, I thought about the hooking up to the outputs... I am going to go for a nice steady red around the sub and a similar glow around the amp I am going to stick on the other side. Remember, the only part of the plexi that is going to be seen is the edge the sub is mounted behind.
