Glovebox light
Old Aug 4, 2010 | 07:38 AM
Burnout666's Avatar
Vehicle: 2001 Tib
Default Glovebox light
I want to install a small stick on led strip as a glovebox light. Is there anyway to set it up so that it only comes on when the glove box is opened?
Old Aug 4, 2010 | 11:42 AM
You'd have to install a switch on the glovebox door somewhere. Run the switch from a switched (not the battery) and fused power source. Put the lamp in the same power loop as the switch, ground it somewhere metal in the dash, and you're done.
Old Aug 4, 2010 | 01:19 PM
tibbytib's Avatar
I added one to my glove box and simply wired it to my parking lights. Figured when its dark enough for headlights, I would probably need a light in my glove box. Not quite as elegant as figuring out a switch and all, but works well.
Old Aug 4, 2010 | 01:32 PM
DO you not have a factory glovebox light? If you do, tap into the wiring for that. I'm just not sure, the GK has one.
Old Aug 4, 2010 | 02:58 PM
RDs don't. You will need a long arm switch or something to turn it on and off.
Old Aug 4, 2010 | 08:48 PM
Just a microswitch at the top/opening of the door, closing the contact when the door is opened. No need to hide it unless you are super-picky.
