Fiberglass help - making the "shell"
Old Jul 1, 2004 | 03:40 PM
batman's Avatar
Vehicle: 01 Tiburon
dual action sander...we used an air one
Old Jul 1, 2004 | 04:04 PM
just out of curiosity... I am going to be doing some glass work soon.. what do people recommend as a release agent for a mold?
Old Jul 1, 2004 | 04:08 PM
BigBoi's Avatar
yeah redtibby, i'll use a sander.. no way in hell i will sand by hand at first.. i'll save that for the finish sanding.
And mold release.... i know they sell actual mold release.. i think the website that Madtib posted was www.selectproducts.com I have also read that you can use WD-40, but i have never tried it. I just use aluminum foil and tape it down, then glass over the foil.
Old Jul 1, 2004 | 04:11 PM
well, as I am doing some of the molding right on the car (bumpers) I do not want to hurt them
Old Jul 1, 2004 | 04:22 PM
batman's Avatar
Vehicle: 01 Tiburon
if your using your bumper itself as a mold i dont believe that mold release would be best because the heat would still transfer thru and you would run a chance of damaging it....i've melted thur plastic bucket because of too much hardener and i could only imagine what it would do to a bumper
Old Jul 1, 2004 | 04:32 PM
BigBoi's Avatar
yeah.. i dont know what to suggest if ur using it on ur bumper(s). As redtibby said, the resin gets pretty hot depending on the amount of hardener you use, i too have melted plastic by using too much hardener...
Old Jul 1, 2004 | 04:36 PM
Boricua's Avatar
check out this web site it may help you out.
http://web.njit.edu/~cas1383/proj/main/
Old Jul 1, 2004 | 05:39 PM
I wasn't going to use glass on the bumper... bondo makes a good mold
Old Jul 1, 2004 | 06:05 PM
MADTIB's Avatar
Bondo,to make a mold???? Not too sure about that, but if you've done it before then I guess you know something I don't. Personally,I'd tape the bumper real good and lay a couple layers of chop mat.You can use painters tape.That won't hurt the paint/clear coat as long as you don't leave it too long.
You guys that say you have melted plastic cups/buckets...........................You must be using waayyy too much hardner.You really don't need that much.Especially in warm/hot ambient temps.Also using too much hardner for glass or bondo isn't good.It can crack/crumble easily.
Old Jul 1, 2004 | 07:12 PM
isn't that the truth....
