factory buttons
Old Oct 8, 2001 | 05:11 PM
daemon696's Avatar
Default factory buttons
OK guys, I went out and bought new buttons ( to replace the dead ones, fog lamp, rear wiper, cruise control, whatever your tibby doesn't have). I figured doing this would be a cool way to use factory buttons, for unfactory mods such as nitrous arming switch or additional lighting ( neons). but when i got the buttons in the mail today, they are attached to a small box that just has a plug in the back. I know there must be a way to wire this up ( figure out which metal prongs are power, ground, remote), does anyone know of a way to get some sort of wiring diagrams, or alter these buttons?
thanx
Old Oct 8, 2001 | 05:19 PM
www.hmaservice.com should have the wiring diagrams for each switch. That...and you should be able to figure it out with a multi-meter.
You should have ground, 12V dimmed power for the light in the switch, 12V live for the switch, then a 12V out of the switch, and possiblly a ground out for the switched item as well. (5 pins)
Old Oct 9, 2001 | 07:11 AM
daemon696's Avatar
thanx Random
what would we do without your wisdom
Old Oct 9, 2001 | 07:20 AM
hyundai jvx's Avatar
Vehicle: 2005 MINI Cooper S
thanx Random
No kidding, I'd jump in front of a throwing ax for Random. Take one for the team!
Old Oct 12, 2001 | 02:15 PM
coupe2k's Avatar
hey daemon- do you have the part numbers for that off hand? I was thinking about this too. Having one as a garage door opener would be cool, maybe the others for nitrous, sub on/off etc.
Old Oct 12, 2001 | 06:41 PM
daemon696's Avatar
what you will have to do is buy the buttons that you dont have. what buttons i boughts was the rear wiper and the fog light button. the fog light button is just like the rear defog button ( shaped like a half moon) and that part number is # 93740-27500. now the rear wiper button is different, it goes inbetween the two crescent buttons ( that center dark gey peice) that part number is # 93610-27500. but i figure you can just order whatever button you want, it just depends on what kind of picture/ or switch you want. go check out http://www.stcharlesauto.com/ they have been a big help in this ( and other things) plus they give an internet discount on all parts. i have a friend that is a mechanic at a hyundai dealership so im going to try and see if he can tell me which metal prongs are which ( power ground etc) im also going to try and find some manuels and do some research on this. when i figure it out ill post it up here so all can see if they want to wire up something to it. i just think its pretty cool to have a 'factory' nitrous switch, or switch for whatever aftermarket part you buy. the factory stylin for the tibby is soooo much better than any generic toggle switch.
Old Oct 15, 2001 | 02:17 PM
coupe2k's Avatar
Thanks! I have everything except ABS though. I was thinking of the left hand side of the dash where some of the buttons aren't actually buttons. Maybe I could put stock ones in that work. Then I could have all my stock stuff on the right, and add nitrous, etc on the left.
