F* Blew Something
Old Nov 23, 2007 | 03:43 PM
I was trying to replace the lighter bulb with an LED, resistor and all. it didn't work, so i reversed the LED and it popped. next thing i know my cluster doesn't light, and the left headlamp and left taillamp don't work.
Old Nov 23, 2007 | 04:00 PM
It's a fuse in the engine bay.
Probly 10A left tail light fuse, or possibly fusable link F (green)
Old Nov 23, 2007 | 04:04 PM
i don't know what could have went wrong, i did everything correctly. green wire is +. it's the first time this has happened.
all signs point to a fuse, but i have no idea which one. i checked all interior fuses, they're ok. so yeah it has to be one from the engine. ^ah ok.
there are some parts of the cluster that do light up but others that do not.
Old Nov 23, 2007 | 04:09 PM
The green/white wire is illumination + Green/black is illumination -. If you hook to illumination - it's grounded though the dimmer switch which can go bad too. The Ill+ includes the cigarette lighter, and the door switches. They are running only on 12V from the fuses.
Old Nov 23, 2007 | 04:10 PM
Daaaaamn Adam!!! You f*cking called it! Left taillamp fuse in the engine. I want to be on your soccer team.
what do you want for christmas?
Old Nov 23, 2007 | 04:13 PM
um... My soccer team lost last time we organized it for physical training.... lol. Howabout a better title under my name for christmas?
Old Nov 23, 2007 | 04:39 PM
haha.gif quite ok, when i played for the girls team a few summers ago it wasn't about winning ...or losing really, if you get my drift fing02.gif
present en route.
how can i test the the LED's on the lighter assembly without blowing another fuse? any idea on what made it blow?
Old Nov 23, 2007 | 04:57 PM
Pretty much there is no good place to test there, unless you make a test cable from a 12v DC lighter plug. Try your overhead lamps, or directly from the battery, or the plug behind the lighter.
I have a friend who dropped a penny into her lighter. She kept blowing fuses. We couldn't figure it out. Once I figured out there was a penny down there, it was a PITA to get it back out. It's just a tight spot to work in.
Old Nov 23, 2007 | 06:51 PM
StrikeEagle's Avatar
Oooh, that was one I could have called if I saw this thread earlier cool.gif
Old Nov 23, 2007 | 07:05 PM
LO f'in L. Thanks for the title! You forgot "a"
