Electrical Problem..what Do You Guys Think?
Basically my left tail lamp fuse from the engine department keeps blowing when the alarm goes on or when I activate it. I even put a 25amp fuse in there because I was getting pissed and was watching to see it blow and it did right infront of my eyes.
It has happened before but not to this extreme where everytime I activate the alarm the fuse pops. Recent electrical work was a volt stabalizer and grounding kit.
Let me know what you guys think, I'm going to check webtech wiring diagram later on tonight.
easy...
your left tail lamp fuse will blow if there is a short in your left tail lamp circuit or illumination circuit. when the alarm arms and disarms, it activates the lights. there is a short somewhere probably near the alarm (-) output for the lights.
yup check your ground connections...
also check the stabalizer connections.
You could also try to remove the wires from the stabalizer (if possible) to check to see if its a faulty stabalizer.
i have the same problem and i have not found the answer. please post if you find the problem.
not only is it my left parking lights but also my gauge cluster lighting.
i cant find a short, and i even have the alarm disconnected to the lights.
yeah the door was open. didnt try it with the door closed. buzzers?
have you found anything else out yet? i still havent. me and my alarm homie are going to check it out tonight but i dont know if its really the alarm now.
ive heard of harness that melts behind the gauge cluster and that its common but hopefully thats not it.
