Door Plastic Panel Holes Cracked ...
As you may all knows, those front door panel holes (2 on each door) made with plastic tend to crack easily. 3 of 4 holes are cracked in mine. I've tried rubber washers to minimize the break.
Can i fiberflass those hole back with the surrounding plastic and drill a new back, will it hold and crack ?
You can buy ABS glue at Lowes or anywhere that sells plummer supplies. Take off the door plastic, coat the back of the crack with the ABS glue, wait for it to dry and drill a new screw hole. It will be good as new.
