Climate Control! HELP?!?
Old Aug 12, 2004 | 10:23 AM
douknowme12321's Avatar
Default Re: CEL p0121, p0506
Well i removed the dash for paint, and took the knobs of the climate control, now that im trying to put them back in, the one all the way on the left(the temp control) doesnt want to budge all the way to the right! Did I break it?
Old Aug 12, 2004 | 10:24 AM
KUJO's Avatar
Default Re: Official Bush vs. Kerry Thread
check if the halfs are aligned
Old Aug 12, 2004 | 10:33 AM
Default Re: Climate Control! HELP?!?
They are they slide in just fine. :?
Old Aug 12, 2004 | 11:10 AM
Default Re: Seat Covers?
that dial is connected to a heater cable which connects to another peice down by the gas pedal.
do a search for "heater cable" on here and you will get detailed pictures and what not.
if you didnt unhook that cable taking the dash off, then it is probably broken.
Old Aug 12, 2004 | 11:31 AM
Hey tibby but if the heater Cable broke wouldnt it move a lot more freely? Wouldnt it be a lot more loose? Mine is basically stuck at a certain point. i hope itz not broken, im hoping it is just caught...
Old Aug 12, 2004 | 11:39 AM
Default Re: Oil Change Intervals
if you didnt unhook it when you took the dash off, you had to screw something up ripping the b**** out.
look down by the gas pedal, there is a yellow armature type thing that the cable hooks to. you have to get the cable on that. try routing the cable to the right of the metal tube in the dash(you'll see it).
Old Aug 12, 2004 | 11:48 AM
Default Re: need help with tires
actually we unscrewed the climate control panel from the actual dash, we did not disconnect any of the plugs off the climate control, we unscrewed everything before removing the dash from the car. My cuzin said on his car, you cannot remove the a/c and heater plugs so he didnt wanna risk it with mine, instead he got a small screwdriver and unscrewed the screws from the back of the climate control 2 separate it. rite now the climate control is where it supposed 2 be with all the cables still intact. the only planel we really took off was the outside.
Oh and by the way those leds are SiKk! Are they hard to install?
Old Aug 12, 2004 | 12:29 PM
First off, do a search, there are plenty of pics and explaniations on how to PROPERLY take your dash apart. You should take it off with all the items installed, otherwise you will break something, as you probably did. Disconnect all the quick connectors, the heater cable, and unscrew the clamp that holds the heater cable in place.
QUOTE (douknowme12321)
Sure you can, he probably just doesn't know how. They are always made to be able to replace parts.
Just disconnect all the connections like you should have done in the first place, mount it on the dash and put it all back together. You probably broke something doing it this way.
Start a new topic, and please, cut out the 12 year old "Wow, dat shiz is the shiz yo, wer can I get sum of dos? Dey b sikk!" talk. It's annoying as hell mang.
Old Aug 12, 2004 | 12:36 PM
Default Re: My Shifter and hand brake handle
LoL ok thanks Redz, you forgot i was new. lol
Old Aug 12, 2004 | 12:39 PM
Nope, didn't forget you were new, just tellin you whazzup.
